jjuly
#1 Posted : Monday, November 21, 2016 8:11:37 AM(UTC)
jjuly
Complaint, will not start. Sensor light comes on.
Diagnostic displays F1 error, primary control failure. No other errors in the memory.
Replaced the board WPW10111617
Start attempt ... same thing. No start, sensor light comes on.
Error now is F2: keypad stuck. Performed tests and the result would be to replace the user interface board. WP8563974
No other errors in memory. Placing the old main board, back to F1 and no other.
Wow, the first board was $236 and if it also needs the second, that's another $265
Also, the repair page said: "control is glued to panel. Panel could be damaged during replacement"
Looking for your advise.
ThatGuy
#2 Posted : Monday, November 21, 2016 1:14:26 PM(UTC)
ThatGuy
Groups: Expert
United States
Check all the connections to the computer and touch panel. Re-seat them and see if it makes a difference.
On some older dryers "F2" can be a thermister problem. I'd check it just to rule it out. If you're not sure how here is a video about it.
https://www.youtube.com/watch?v=oaABV5WV6sI
Part no. 9 on this diagram.
Parts for Whirlpool WGD6400SW2: Bulkhead Parts - AppliancePartsPros.com
jjuly
#3 Posted : Monday, November 21, 2016 3:23:11 PM(UTC)
jjuly
Thanks, although I did check the connectors on the main board, I'll go back and check again, as well as checking the temp thermistor and running more of the diagnostic tests.
Guest (4)
Whirlpool WDTA50SAHZ0 no start, flashing lights (Dishwasher Repair)
by lewist57 9/15/2023 2:30:03 PM(UTC)
Frigidaire Affinity NO START, the light is not on when the door is open (Dryer Repair)
by Guest 3/13/2022 9:02:49 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Dryer Buzz and no start (Dryer Repair)
by rsangus 2/3/2019 10:11:41 AM(UTC)
Frigidaire Dryer beeps 3 times - no start (Dryer Repair)
by boriska13 6/27/2017 8:59:46 PM(UTC)
Click no start (Dryer Repair)
by leftymurphy 6/1/2017 3:24:01 PM(UTC)
kitchenaid dishwasher no start (Dishwasher Repair)
by jr1397 3/11/2017 7:52:29 AM(UTC)
Roper Washer no Start (Washer Repair)
by bellmd 1/21/2017 6:08:14 AM(UTC)
Frigidaire Dryer No start (Dryer Repair)
by Cable Guy 4/1/2016 5:47:49 PM(UTC)
Inglis Electric Dryer itermittent no start (Washer Repair)
by Tom Colins 12/5/2015 4:45:55 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
dryer makes noise but no start (Dryer Repair)
by joe7875 7/23/2013 4:26:05 PM(UTC)
maytag centennial no Start (Washer Repair)
by tjspeed25 3/18/2013 10:59:46 AM(UTC)
Gas Dryer buzzes & no start on occasion. (Dryer Repair)
by techman_hou 5/26/2012 4:03:32 PM(UTC)
No start problem related to float in Bosch DW (Dishwasher Repair)
by jasper88 5/15/2012 4:47:49 PM(UTC)
