reimanns
#1 Posted : Wednesday, November 2, 2016 1:14:42 PM(UTC)
reimanns
i have replaced the door boot on a Frigidaire Affinity washer. The boot is fully installed, all springs are in place. The door will not close. It is catching on the boot at the bottom. I have verified the boot is seated all the way around. Any suggestions what I should check or change?
brobriffin
#2 Posted : Thursday, November 10, 2016 2:38:31 PM(UTC)
brobriffin
Man
United States
I am curious, why did you have to replace the boot on such a young machine?
Was it the door possibly being out of line that caused the first boot to go bad?
If the door is sagging then this may be the problem.
