3 Pages<123>
ThatGuy
#11 Posted : Wednesday, November 2, 2016 12:11:26 PM(UTC)
ThatGuy
Groups: Expert
United States
This will probably sound odd, but how warm is the room you do laundry in? Do you do mostly cold water washes?
jelly_rockstar
#12 Posted : Wednesday, November 2, 2016 12:39:17 PM(UTC)
jelly_rockstar
Originally Posted by: ThatGuy Go to Quoted Post
I was thinking it might be the lid switch, but after messing with my machine it now seems unlikely.
I'm now thinking the problem is inside the gearcase. I've seen behavior like this before. There is a part called a spin paw that swings out and engages the big spin gear. It comes with a kit, but its a fairly difficult job to replace.
diagram of gearcase:
Parts for Maytag MVWC7ESWW0: Gearcase Parts - AppliancePartsPros.com
Kit:
Whirlpool 388253 Neutral Drain Kit - AppliancePartsPros.com
Well, I hope that isn't the issue!!! Looks a lot more expensive and difficult than the clutch!
jelly_rockstar
#13 Posted : Wednesday, November 2, 2016 12:40:34 PM(UTC)
jelly_rockstar
it depends never below 50 degrees Fahrenheit but has hot as 90 degrees.
only cold water washes - rarely do a hot water wash
ThatGuy
#14 Posted : Wednesday, November 2, 2016 2:42:04 PM(UTC)
ThatGuy
Groups: Expert
United States
The reason I asked is because the gearcase is filled with 50 weight oil. Very thick and at lower temperatures the parts in it will be very sluggish.
This washer is designed to operate in temps above 70 F. Try doing a wash on a warm day using warm or hot water. See if it manages to spin on its own.
Believe it or not, I've ran in to this problem a few times, usually during Winter.
(the cold water transfers the cold straight down the agitator shaft into the gearcase)
jelly_rockstar
#15 Posted : Wednesday, November 2, 2016 2:51:50 PM(UTC)
jelly_rockstar
Should I try doing one with hot water?
jelly_rockstar
#16 Posted : Wednesday, November 2, 2016 3:50:12 PM(UTC)
jelly_rockstar
Okay I don't know why I didn't think of this sooner...
Here is a video of the washer in action
https://youtu.be/CgmiOvY1QNI
https://youtu.be/MmDaJno0Y1w
ThatGuy
#17 Posted : Wednesday, November 2, 2016 9:00:43 PM(UTC)
ThatGuy
Groups: Expert
United States
The first video was going pretty good, but you interrupted the drain by opening the lid which prematurely started the spin part of the cycle.
I was hoping to see it drain for a couple of minutes and then see whether it paused and then came back on spinning or not.
Definitely do a hot load and leave the lid alone to see if it will activate the spin on its own.
jelly_rockstar
#18 Posted : Wednesday, November 2, 2016 9:08:27 PM(UTC)
jelly_rockstar
I will do another video. It doesn't activate spin that's why I opened the lid. You can hear the motor free spinning.
ThatGuy
#19 Posted : Wednesday, November 2, 2016 9:43:56 PM(UTC)
ThatGuy
Groups: Expert
United States
You probably need a neutral drain kit put in.
Here is a video. You only need to take it apart until 2:47 and start reassembly at 6:12. You don't need to remove all the oil, just keep the gearcase level.
https://www.youtube.com/watch?v=ieZ5y47TAMk
jelly_rockstar
#20 Posted : Thursday, November 3, 2016 7:53:11 AM(UTC)
jelly_rockstar
I don't know what's going on with this thing. I just did my second load of laundry and it worked just fine....
Guest (7)
3 Pages<123>
