atem2144
#1 Posted : Friday, October 28, 2016 12:34:41 PM(UTC)
atem2144
I have a Maytag dryer that is overheating, the heating element never cycles off even in the air only setting. I have replaced the thermal fuse and high limit t-stat, did not help. When I test the heating element for a short/grounded out, with wires disconnected I have no continuity when I touch either terminal to the case. When I test it with the wires connected it has continuity when I touch the terminals to the case. I took the heating element out and it looks good, no sagging wires, no damaged insulators, no wire breaks. What makes the heating element cycle in this machine?
ThatGuy
#2 Posted : Friday, October 28, 2016 4:24:26 PM(UTC)
ThatGuy
Groups: Expert
United States
It sounds like a stuck relay on the control board.
Whirlpool WP8546219 Control Board - AppliancePartsPros.com
Watch the video. At 4:07 you can see the word "heater" on the board next to the big relay. That is probably the one.
Maytag Dryer Overheating (Dryer Repair)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
