Dryer not heating change thermistor, fuse ,thermostat , PCB board, still not heating, check the touch sensor (adjust time up +temp press key for 7sec) is ok dry 0 wet cloth 1 , then check the motor and heater the result is OK on the display ( by the way is the only time the heater work) Jumping the heater relay work too . So next to change the sub board (display and dial) ?
