Drying is running but will not heat. There are no error codes. We have checked circut breaker, removed the ducking and cleaned and checked for obstruction. With the ducking removed when turned on it blows cold air out of the vent in the back. The dryer is 2 1/2 yrs. old. Does anyone know what the possible fixes that would be needed are?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Samsung dryer, started not drying all the way and had to run it twice now it will not heat up at all. Vent line is short, new and clean
