How do I remove the lower spray arm and the plastic screen to clean out my dishwasher. GE Modale Number GHDA475M00CS.
The lower spray wash arm can be removed by gently lifting and rotating it counter clock wise. The nut hub can be removed by rotating it counterclockwise. Caution: Use care to avoid breaking the clip on the hub when removing the main conduit from hub. |
THIS FORUM IS DEAD!!!!!!! |
Can you buy just the part with the clip? Mine broke despite me being really careful. The entire arm to replace is at least $60, I was hoping to just replace the part with the clip. Is that possible?
