3 Pages<123>
Joe / APP Team
#11 Posted : Friday, September 3, 2010 5:45:06 AM(UTC)
Joe / APP Team
Originally Posted by: ebenfowler Go to Quoted Post
And one more bit of data. Since the pulley spun freely both directions, I was not able to go through the brake disengagement adjustment where you try different washer thicknesses. I could only fit the thin washer on the shaft and manage to install the E-clip. So I just put it back together, set the washer upright, plugged it in and set it to the spin portion of the cycle. When I peered into the tub with a flashlight, it appeared to be agitating. Don't know if this tells you anything important or not, but...
Eben,
You don't have the proper adjustment.
(pay close attention to the top of page 3 in the instruction sheet).
It may take several "adjustments" to get close to the proper cam range, and then "fine" tune it from there.
Most technicians, used to align the arrows and stack the washers, until the E clip slot could barely be seen, then used a small thin blade screw driver to "pry" out on the shaft and set the E clip.
That used to work rather well, you may want to try it ??
I attached the instruction sheet, just in case.
Good Luck,
http://servicematters.co...ibrary/docs/16022521.pdf
Angel45005
#12 Posted : Wednesday, October 19, 2016 5:38:07 AM(UTC)
Angel45005
Originally Posted by: Joe / APP Team Go to Quoted Post
Eben,
Good Luck,
I wish this person would have followed up and told if they fixed the problem.
Joe / APP Team
#13 Posted : Wednesday, October 19, 2016 7:33:18 AM(UTC)
Joe / APP Team
Angel, A response or update from the customer would be nice, but it doesn't always happen. In your case "the washer wont spin by hand" is approached from two ways. If you can reach in the tub and turn it by hand, then approach it from the bottom and the thrust bearing kit. If you can't turn the tub by hand, then suspect the tub bearing assembly is seized to the transmission. You'll need to be careful, the washer needs to be in the spin cycle and running, you'll need to hold the lid switch down and turn the tub by hand at the same time.
Angel45005
#14 Posted : Wednesday, October 19, 2016 12:34:24 PM(UTC)
Angel45005
Wow. That seems easy enough. Yes the tub will not move at all, its like its frozen there.
Thanks for replying. Ill let you know what happens.
Angel45005
#15 Posted : Wednesday, October 19, 2016 12:37:40 PM(UTC)
Angel45005
Oh I forgot to ask. If the tub bearing assembly is seized to the transmission, all I have to do to fix that is try to turn the tub by hand while the machine is in the spin cycle? No parts needed?
Joe / APP Team
#16 Posted : Wednesday, October 19, 2016 12:40:43 PM(UTC)
Joe / APP Team
Angel, Yes, it's not very difficult a machine to diagnose and repair. You'll have it diagnosed in a couple of minutes. Will keep an eye out for your next post.
Angel45005
#17 Posted : Wednesday, October 19, 2016 12:56:35 PM(UTC)
Angel45005
Hey Joe, I wanted to tell you that I had also posted my question here after replying to this one. I got one answer on it. I hope your solution fixed it though as it's free :).
Anyway, the other one I was told it was the Thrust bearing kit.
Will see. Ill be back!
Joe / APP Team
#18 Posted : Wednesday, October 19, 2016 1:04:06 PM(UTC)
Joe / APP Team
Angel, You'll know what's what in a couple of minutes. let us know what you find
Angel45005
#19 Posted : Wednesday, October 19, 2016 7:16:32 PM(UTC)
Angel45005
Joe, I'm so excited. Even my daughter was laughing at me, I was so ecstatic. Your solution worked!!! Yes. Thank you so very much. And it didn't cost a penny. As soon as I tried to move the tub it took off. To make sure I even marked an on the tub with a permanent marker and sure enough, its working. I believe that we reap what we sow. I got a reaping and yours is coming. Thanks again Joe.
Joe / APP Team
#20 Posted : Thursday, October 20, 2016 5:01:57 AM(UTC)
Joe / APP Team
Angel, Great... You'll be Ok for a few days, but get that thrust bearing kit Part number: AP4009132
ordered and installed as soon as possible. Thanks Again,
3 Pages<123>
