I have a Kitchenaid refrigerator (KSCS23INSS01) and the top shelf lights on the fridge side will not work. I tried new bulbs, but didn't work. Lower down in fridge side there's another light that goes on fine. The freezer lights work fine. The lights on the water/ice dispenser work fine. It's just the top two bulbs on the fridge side that are not working. Both went out about 6 months ago and I was able to get one replacement bulb to work (the other socket didn't work after that). Now, both sockets will not work with new bulbs.
Any thoughts? Thanks.
Groups: APP Team
Originally Posted by: RowRow  I have a Kitchenaid refrigerator (KSCS23INSS01) and the top shelf lights on the fridge side will not work. I tried new bulbs, but didn't work. Lower down in fridge side there's another light that goes on fine. The freezer lights work fine. The lights on the water/ice dispenser work fine. It's just the top two bulbs on the fridge side that are not working. Both went out about 6 months ago and I was able to get one replacement bulb to work (the other socket didn't work after that). Now, both sockets will not work with new bulbs.
Any thoughts? Thanks. Hi there, I realize this is an old post, but I'm in the same situation and wondering whether you found a solution? Any advise would be much appriciated.
You can contact to service center and they are solve your problem properly.
