Getting an F02 code, won't drain.Took filter out and cleaned,was plugged, have continuity on pump motor, pressure sensor tube not plugged. blew threw. I can here pressure switch click when i blow into it. I can not get it into diagnostic mode. put it on spin/drain, no spin, hold prewash button for 5 seconds,and have three dashes in time display.
