Two Position Temperature Function Switch Not Working When Switched To High Heat
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Have you used a multimeter to check if the switch is bad?
Originally Posted by: brobriffin Have you used a multimeter to check if the switch is bad? Hi, In order to use any multimeter, it is necessary to to begin by removing the control panel to access the back plate. Unfortunately, I have found no one able to tell me how to remove the control panel on this combo washer dryer. I have removed all of the front dials....but the control panel has to be removed in order to remove the washer timer knob. But I am at a loss trying to remove the control panel.
