3 Pages<123
brobriffin
#21 Posted : Wednesday, September 28, 2016 3:56:34 PM(UTC)
brobriffin
Man
United States
Ok in the mean time do you know anyone that might have a digital multimeter?
If so see if you can borrow it and test the heating element. I believe it may be good. Your tester may not be whats needed to check this.
spelding
#22 Posted : Wednesday, September 28, 2016 4:00:00 PM(UTC)
spelding
Hey bro.
Having trouble with the Manage Attachments feature. When I click on Choose File, nothing happens. If you don't mind, text me your phone number and I'll send them from there I know that works. My number is 609 431-3539. I took pictures of the various component and the heating element.
spelding
#23 Posted : Wednesday, September 28, 2016 4:02:19 PM(UTC)
spelding
OK. I'll talk to my next door neighbor. He has just about everything. Does the multimeter work the same way as a continuity tester? I'm guessing there would be meter or numerical output. If so, what should it be testing at.
spelding
#24 Posted : Wednesday, September 28, 2016 4:04:39 PM(UTC)
spelding
If he doesn't have one, I'll just go to Lowe's or Home Dept , buy one and then return it when I'm done. How much would it cost for a multimeter that will give me the readings I need to see?
spelding
#25 Posted : Wednesday, September 28, 2016 4:37:09 PM(UTC)
spelding
I know you mentioned in a previous post that you were only interested in the two large terminal connections on the cycling thermostat. I just happened to test the smaller connections on the cycling thermostat and the light on the continuity tester did not light. I should have read your earlier post where you suggest replacing the cycling thermostat.
Does this mean the cycling therm is bad?
spelding
#26 Posted : Wednesday, September 28, 2016 4:49:12 PM(UTC)
spelding
Sorry for the flurry of posts but could you give me the party number for the cycling thermostat? I tried doing a search on this site and I didn't see anything that looked like the one I currently have. Maybe they updated the part like they did with the hi limit thermostat. Thermos
Whirlpool Dryer won't heat (Dryer Repair)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
Whirlpool dryer won't heat during auto cycle (Dryer Repair)
by Pdcrull 9/7/2014 8:52:29 PM(UTC)
Whirlpool Dryer Won't Heat (Dryer Repair)
by rebecca0101 9/4/2014 10:46:27 AM(UTC)
Whirlpool dryer won't heat (Dryer Repair)
by jev 12/7/2011 5:34:31 PM(UTC)
by Rans 2/12/2010 11:52:28 AM(UTC)
Whirlpool Dryer won't heat up (Dryer Repair)
by jmrobeck 9/2/2008 10:59:58 AM(UTC)
by haddy 8/14/2008 7:44:34 PM(UTC)
3 Pages<123
