dap4cep
#1 Posted : Tuesday, September 20, 2016 8:57:07 AM(UTC)
dap4cep
I have a Maytag dryer that wont run. All of the indicator lights flash and wont clear. I've tried unplugging it and then plugging the dryer back it and it doesn't make a difference. I also checked the fuse and thermistor. The fuse is good but the thermistor is bad. I jumped it out and it doesn't make a difference regarding the indicator lights on the panel. I also found that the thermistor is no longer available. I'm hoping someone has run into this before and can help me out.
ThatGuy
#2 Posted : Sunday, September 25, 2016 2:44:50 PM(UTC)
ThatGuy
Groups: Expert
United States
Jumping a thermister won't work. It has different resistance reading at different temps.
Do a search on google for "how to test thermistor" There is a video that explains it.
I would think its your main computer, but I really don't know this model at all. Good luck.
Just for fun I looked it up. Its nla. That sucks.
http://www.appliancepartspros.c...-33003028-ap4044079.html
Guest (4)
