I have a Maytag dryer that wont run. All of the indicator lights flash and wont clear. I've tried unplugging it and then plugging the dryer back it and it doesn't make a difference. I also checked the fuse and thermistor. The fuse is good but the thermistor is bad. I jumped it out and it doesn't make a difference regarding the indicator lights on the panel. I also found that the thermistor is no longer available. I'm hoping someone has run into this before and can help me out.
Groups: Expert
Jumping a thermister won't work. It has different resistance reading at different temps. Do a search on google for "how to test thermistor" There is a video that explains it. I would think its your main computer, but I really don't know this model at all. Good luck. Just for fun I looked it up. Its nla. That sucks. http://www.appliancepartspros.c...-33003028-ap4044079.html
