Hello,
I live in an apartment that was provided with a washer and dryer by the landlord. The washer is a Whirlpool Duet front loading. It continually smells moldy so I went to clean the bellows and it was caked in mold/mildew. In the process the bellows slipped and I am not sure how to get it back on properly or how it should be fitted on/where it attaches to/etc.
There is a heavy dryer on top of it and it is pushed into a closet so I cannot take it out to remove the top or anything like that.
I just need to know if the bellows attaches itself to the actual washing drum part of the washer and how to get it back on.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
It should be attached with a wire/spring band. This band belongs in the groove around the bellows holding it on the lip inside the door. Watch Matt in this video show you how! https://www.youtube.com/watch?v=7uEk61JOgRk
