bchessa
#1 Posted : Saturday, May 3, 2008 11:07:14 AM(UTC)
bchessa
there is water leaking in the freezer compartment and forming ice at the bottom shelf. I have turned off the water to the fridge thinking maybe the ice maker was leaking and the problem is still there.
Where should I be looking to solve this problem?
misterfixall
#2 Posted : Saturday, May 3, 2008 3:20:31 PM(UTC)
misterfixall
It Sound Like Drain Is Blocked In Drain Trough Behind Freezer Panel .the Easiest Way Is To Defrost Fridge An Unblock Drain Trough To Drain Pan Under Fridge ,i Use Compressed Air To Blow It Clean , Who Knows What You Will Find In Hose ,when I Am At A Customer I Use A Commercial Heater Gun To Melt The Ice In Drain
Dean Haustead
#3 Posted : Thursday, September 8, 2016 11:18:55 AM(UTC)
Dean Haustead
Water leak problem is very bad symtoms for all fridge. Watch this prolem becaze still have running this problem your fridge ice maker is not working.
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Frigidaire - Water Leaking from Electronic Defrost Control Area????? (Trash Compactor Repair)
by BJPrice 2/1/2018 3:20:07 PM(UTC)
Water leaking from brand new LG door in door fridge (Refrigerator & Freezer Repair)
by Jason B 7/20/2017 12:58:06 PM(UTC)
Water Leaking at Water Inlet Valve (Refrigerator & Freezer Repair)
by marshmore 12/24/2015 8:00:34 AM(UTC)
water leaking? in freezer (Refrigerator & Freezer Repair)
by chknmom 10/16/2015 3:50:20 PM(UTC)
water leaking on floor (Refrigerator & Freezer Repair)
by capetish 8/23/2015 6:39:00 PM(UTC)
Ice build up bottom of the freezer and water leaking the front door unto the floor (Refrigerator & Freezer Repair)
by BEbner 5/22/2015 1:56:55 PM(UTC)
water leaking from soap dispenser housing (Washer Repair)
by suekevin 1/8/2015 12:21:56 PM(UTC)
