tekgeek
#1 Posted: : Wednesday, August 24, 2016 7:57:05 PM(UTC)
tekgeek
So I bought a matching washer and dryer set, guy says its 1 year old. I brought them home and I find the dryer does not start it just hums. I talked to the guy he asked me to bring back the dryer and so I do we plug it in and it works at his place. I bring it back and it still does not work. Thinking its the house wiring I replaced the 30A dual pull breaker checked the wire its 10/2 and I replaced the plug at the wall. It still does not work so I have researched and checked everything. If I tape the door switch down and push the power button and spin the drum it will kick on and run. I finally pulled the pulley and belt off the motor and it starts up. does anyone think that it is just the motor?
tekgeek
#2 Posted : Saturday, August 27, 2016 3:02:43 PM(UTC)
tekgeek
Well I went out today and bought a motor for this dryer cost me 130 dollars with tax. I got it home and installed it and it still does the same thing it hums.
if I tape the door button down and spin the drum while holding down the power button it will click and then start going on its own and I get heat as well. I know I won't be able to return the motor because the old one may have been dinged while trying to take it out.
I am thinking it may be the relay? the timer dial is the only thing I can think of that I can replace.
brobriffin
#3 Posted : Wednesday, August 31, 2016 8:45:48 AM(UTC)
brobriffin
Man
United States
It worked at his house and a different motor nets the same results??? I suspect something is wrong with your power system. Low voltage to L1 or a bad neutral return. If you are able (and have good neighbors) try the unit at a friends house to verify.
tekgeek
#4 Posted : Tuesday, September 6, 2016 4:43:43 PM(UTC)
tekgeek
just wanted to close this post I found that it was my electrical the electrician wired it wrong there was 10/2 wire to the plug but he had wired it as two hots and a ground so my meter showed 120 for each hot and 240 across
after looking at it again I found the ground should have been on the neutral so I moved it over and everything worked
brobriffin
#5 Posted : Wednesday, September 7, 2016 4:47:45 AM(UTC)
brobriffin
Man
United States
Tekgeek, I'm glad to hear it's resolved. If you ever need additional help please return to our forum.
roper dryer not starting..new motor still no start (Dryer Repair)
by skraps528 10/22/2008 5:14:08 PM(UTC)
