AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag timer will not adavance and dryer will not turn off
Hello all, I have a maytag performa dryer that will not turn off using the timer. If i open the door the unit turns off and if i advance the timer manually to the off position it will turn off. Dryer gets hot and clothes are drying. It will do this in all timer settings. If i open the door the dryer will turn off but if i put my ear close to the timer i still hear it buzzing. I suspect the timer is at fault but looking for some advice. model is mde3500ayw ser # 40411503ac
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
If the timer motor is still running as you say you can hear it buzzing then the gear may be stripped. This is not completely uncommon in a 14 year old machine. Try replacing the timer, here is your part number Whirlpool WP33001634 Timer - AppliancePartsPros.com Don't be concerned about the Whirlpool label as Whirlpool now owns Maytag.
Timer did not fix the problem. Timer still does not advance and still makes a buzzing sound when dryer is off.
Dryness display fixed the dryer, thanks for the help
Dryer Repair
