Joe966
#1 Posted : Wednesday, August 24, 2016 8:35:49 AM(UTC)
Joe966
While testing the thermal switch on my dryer, it grounded and made a pop. Now, after putting a new switch in it does nothing when i try to start it. I tested the start switch with an omh meters and it is fine. Think i may have blown the motor. Any advice?
brobriffin
#2 Posted : Wednesday, August 24, 2016 11:56:32 AM(UTC)
brobriffin
Man
United States
When checking for possible causes of dryer issues, please check to see if the circuit breaker tripped. It may not look like it has but turn it off then back on.
If you still don't have a response then, possibly you may have blown the thermal fuse. See part 36 in diagram.
Parts for Frigidaire FSE748GFS1: P16V0037 Dry Cab,heater Parts - AppliancePartsPros.com
Remember when checking and servicing your appliances please disconnect the power before opening the case!
DRYER does nothing (Dryer Repair)
by mar1270 5/1/2014 10:47:39 AM(UTC)
Roper dryer does nothing (Dryer Repair)
by Influencer 7/17/2013 3:01:53 PM(UTC)
by pilsner 9/4/2012 10:49:26 AM(UTC)
by rob2010 7/31/2010 1:18:26 PM(UTC)
by 1955fordnut 1/24/2010 8:03:36 PM(UTC)
Dryer does nothing (Dryer Repair)
by smallies 10/21/2008 6:42:54 PM(UTC)
Whirlpool dryer does nothing (Dryer Repair)
by Jon P 8/6/2008 6:44:24 PM(UTC)
