While testing the thermal switch on my dryer, it grounded and made a pop. Now, after putting a new switch in it does nothing when i try to start it. I tested the start switch with an omh meters and it is fine. Think i may have blown the motor. Any advice?
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
When checking for possible causes of dryer issues, please check to see if the circuit breaker tripped. It may not look like it has but turn it off then back on. If you still don't have a response then, possibly you may have blown the thermal fuse. See part 36 in diagram. Parts for Frigidaire FSE748GFS1: P16V0037 Dry Cab,heater Parts - AppliancePartsPros.com Remember when checking and servicing your appliances please disconnect the power before opening the case!
