gowestwardho
#1 Posted : Sunday, August 21, 2016 5:44:18 PM(UTC)
gowestwardho
Back in 11/02/2009 "radioman464" posted a request for help on a Maytag stackable washer. It was answered by "sidfink43", in which he posted a link to a Service Bulletin ( http://www.servicematters.com/maytag...DL-0052A-B.pdf ) that will not open for me since I do not have a subscription to Maytag service bulletins apparently.
Here is the original thread: http://forum.appliancepartspros...d-keeps-burning-out.html
I believe I am having a similiar issue with my Maytag stackable washer in that I recently (4 months ago and only half a dozen loads run) installed a brand new Control Board which has now apparently malfunctioned again as the washer WILL NOT DRAIN.
Does anybody have a way to send me this Service Bulletin having to do with "wax motors" (whatever those are?). I hesitate to throw another $160 control board int this infrequently used machine only to have it go out again. SO what to do?
Thanks so much for any advice or input and/or that PDF bulletin I cannot open to read.
gowestwardho
#2 Posted : Sunday, August 21, 2016 5:49:51 PM(UTC)
gowestwardho
The control board part number I reference in this request and that I recently replaced was Whirlpool Washer Control Board #12002651
I am getting an Error Code "ND" (not draining). Unplugged unit and sped it would clear codes but it did not. Also tried only running DRAIN, and other short wash settings (rinse, etc.) but it still will not drain which is similar to what happened when I had to replace the board a few months ago.
Any help or advice?
