Ramfan64
#1 Posted : Sunday, August 7, 2016 9:47:40 PM(UTC)
Ramfan64
Door locked. Sounds like water pump comes on when plug in and light on by locked door
brobriffin
#2 Posted : Monday, August 8, 2016 4:28:54 AM(UTC)
brobriffin
Man
United States
This may sound odd but the computer was fooled when you had the water off. Plug it in and let the drain pump run perhaps for 5 to 10 minutes. If you leave it alone it may reset and perform properly. It must complete whatever cycle it thinks its in to continue. ( I just did a service call with similar issue and this worked for me. The customer had left the cold valve off and when it went to rinse [all rinses are usually cold] the machine thought it was filling but never did.)
Ramfan64
#3 Posted : Monday, August 8, 2016 6:55:40 AM(UTC)
Ramfan64
Thanks I appreciate it. I will try it.
