Noodle
#1 Posted : Wednesday, July 27, 2016 7:04:00 PM(UTC)
Noodle
Hello,
I have a kenmore 600 series dryer that the timer won't go past the 30 minute mark. The dryer gets hot but timer stops at 30 minutes. Should I replace the timer or could their be a bigger problem?
brobriffin
#2 Posted : Thursday, July 28, 2016 4:17:05 AM(UTC)
brobriffin
Man
United States
If this happens whether you set the timer for only 40 minutes or the maximum time setting then I suspect the plastic gear inside the timer may be bad. Will the timer run a complete cycle in the other settings? Will it complete the cycle if you turn it a bit past thirty minutes manually?
Whirlpool WP3976576 Timer - AppliancePartsPros.com
Noodle
#3 Posted : Thursday, July 28, 2016 5:46:40 AM(UTC)
Noodle
Yes the dryer will complete the cycle but the knob won't go past 30 minutes.
brobriffin
#4 Posted : Thursday, July 28, 2016 6:23:17 AM(UTC)
brobriffin
Man
United States
Having a system that runs, heats and completes a cycle as you say but the timer stops at 30. Sounds like a timer replacement will solve your issue. Whirlpool WP3976576 Timer - AppliancePartsPros.com
Noodle
#5 Posted : Thursday, July 28, 2016 10:00:30 AM(UTC)
Noodle
Thank you very much!
Guest (4)
