NYMountainair
#1 Posted : Monday, July 18, 2016 7:29:27 PM(UTC)
NYMountainair
dryer heats for approximately 4 minutes then stops heating. When first starting the dryer I get 0 volts ac across the flame sensor switch (closed), igniter glows and flame kicks on. after 4 minutes flame goes out and I have 118 volts ac across flame sensor switch(open). after about 1 minute I have 0 volts across the flame sensor switch, igniter glows but no flame. Ignitor glows for about 10 seconds then goes out and there is 118 volts across the flame sensor switch(open). this repeats approximately every minute after. I watched it do this three times before I shut the dryer off. I feel this is a problem with the burner system, possible coil? It looks like I have to take the front of the dryer off to get to the burner. How do I do that. Please help!
brobriffin
#2 Posted : Friday, July 22, 2016 6:22:33 AM(UTC)
brobriffin
Views messages in topic : 781
Man
United States
Your part can be found here as well as a video of the repair. Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
NYMountainair
#3 Posted : Friday, July 22, 2016 7:17:40 AM(UTC)
NYMountainair
Purchased and installed valve coil kit. dryer working again. It was fun trying to figure out how to get to the gas burner valve though. Had to figure out how to take the whole front of the dryer apart to get to the coils.
Old Maytag dryer stops heating after few minutes (Dryer Repair)
by OmaDee 6/23/2015 8:11:24 AM(UTC)
Gas Dryer stops heating(not thermal fuse or coils) (Dryer Repair)
by Mpaavo82 9/27/2014 7:51:37 PM(UTC)
Dryer stops heating after a couple minutes (Dryer Repair)
by pdcbus#175 3/22/2014 6:35:45 AM(UTC)
Dryer stops heating during the cycle (Dryer Repair)
by juicejug 10/29/2012 12:42:19 PM(UTC)
Dryer stops heating after 5-10 minutes (Dryer Repair)
by dangtoo 8/17/2012 5:28:23 PM(UTC)
Whirlpool Gas Dryer Stops Heating (Dryer Repair)
by mwyofa 10/7/2011 7:50:36 AM(UTC)
gas dryer stops heating (Dryer Repair)
by billshaf 6/6/2011 4:14:04 AM(UTC)
by maclc 7/20/2008 9:52:22 AM(UTC)
