LucasSteven1day
#1 Posted : 11 years ago
LucasSteven1day
4 months ago the coil froze solid on this unit. I opened the back of the freezer compartment and checked resistance on the defrost heater and it checked out OK, so I replaced the defrost switch. The unit ran fine until yesterday, it froze up again. I rechecked the heater and switch and they both appear to be fine. Is there something else on this unit that controls the defrost heater?? (eg defrost timer, control board):(
#2 Posted : 11 years ago
Parts for Whirlpool GB2FHDXWS03 Refrigerator - AppliancePartsPros.com
See the attachment for your tech sheet.
Yes the control board (item 5 in section 04) runs the defrost cycles.
You could unplug the unit and measure from J1-pin 1 (L2 N) to J1-pin 5 (STAT).
If you measure the defrost heater resistance then you know the heater and defrost thermostat are OK so it must be a board problem.
File Attachment(s):
GB2FH.pdf (721kb) downloaded 26 time(s).
CurtDawg77
#3 Posted : 11 years ago
CurtDawg77
Just wondering how to check these? I already ordered a control board to try out as I didn't see anywhere in the diagrams/part lists either of these two parts. Thanks in advance....
#4 Posted : 11 years ago
The defrost heater is item 10 in section 06.
The defrost thermostat is not shown.
See the below.
The defrost thermostat should be 0 ohms when frozen.
The defrosts heater should be about 30 ohms,
Part number: AP4428815
bloodaxe23
#5 Posted : 9 years ago
bloodaxe23
Denman I have been looking at this post and hope you can help me out. I have the same issues and stupidly ordered a circuit board after reading another post about a S in service mode meant a bad board. I see now I should have tested the heater circuit and thermostat circuit. I am trying to figure out if I can test these individually or is this best replaced as a group? thanks for the help..
#6 Posted : 9 years ago
If the heater is bad then I would replace both.
If the heater is OK then I would just replace the defrost thermostat.
Also if the thermostat measures OK but is deformed/bulged, replace it.
bloodaxe23
#7 Posted : 9 years ago
bloodaxe23
So I tested it last night and got 30ohms of resistance testing at pins 1 and 5 I saw thats good for the heater so thats probably ok? Should it also have resistance for the thermostat? And since Im getting the S on the panel when tested then most likely the thermostat is shoeted?
#8 Posted : 9 years ago
[COLOR="Blue"] I saw thats good for the heater so thats probably ok?[/COLOR]
Yes it looks OK
[COLOR="Blue"]Should it also have resistance for the thermostat?[/COLOR]
The thermostat should be 0 ohms when frozen and 56 Kohms (56,000) when thawed.
[COLOR="Blue"]And since Im getting the S on the panel when tested then most likely the thermostat is shoeted?[/COLOR]
Depends if it is frozen or thawed.
MayTag defrost issues ????? (Refrigerator & Freezer Repair)
by HHM1435 7 years ago
GE side by side defrost issue (Refrigerator & Freezer Repair)
by Craigesh 10 years ago
Maytag MFB2055YEM Defrost Issue (Refrigerator & Freezer Repair)
by david@tidycottage.ca 10 years ago
Defrost issue possibly?? HELP WRF989SDAM00 (Refrigerator & Freezer Repair)
by IslandWarrior 11 years ago
GE Defrost Issues (Refrigerator & Freezer Repair)
by WVU 11 years ago
by MelissaBarrera 11 years ago
Diagnosing GE defrost issue (Refrigerator & Freezer Repair)
by tbarnett 11 years ago
defrost issues (Refrigerator & Freezer Repair)
by jbain7005 11 years ago
Freezer Defrost Issues (Refrigerator & Freezer Repair)
by smuth10 12 years ago
Amana defrost issue (Refrigerator & Freezer Repair)
by CapeCoddah 12 years ago
defrost issue? (Refrigerator & Freezer Repair)
by Frankie_Z 12 years ago
GE PDS18SBMBLBS Defrost issue (Refrigerator & Freezer Repair)
by ldavisfl 12 years ago
GE Profile Defrost Issue - Very Frustrated (Refrigerator & Freezer Repair)
by jaypp1 13 years ago
GE Defrost Issue (Refrigerator & Freezer Repair)
by cmbicycles 13 years ago
Defrost issues (Refrigerator & Freezer Repair)
by zeke7237 14 years ago
