LucasSteven1day
#1 Posted : Wednesday, April 16, 2014 5:54:24 PM(UTC)
LucasSteven1day
4 months ago the coil froze solid on this unit. I opened the back of the freezer compartment and checked resistance on the defrost heater and it checked out OK, so I replaced the defrost switch. The unit ran fine until yesterday, it froze up again. I rechecked the heater and switch and they both appear to be fine. Is there something else on this unit that controls the defrost heater?? (eg defrost timer, control board):(
#2 Posted : Thursday, April 17, 2014 2:36:43 AM(UTC)
Parts for Whirlpool GB2FHDXWS03 Refrigerator - AppliancePartsPros.com
See the attachment for your tech sheet.
Yes the control board (item 5 in section 04) runs the defrost cycles.
You could unplug the unit and measure from J1-pin 1 (L2 N) to J1-pin 5 (STAT).
If you measure the defrost heater resistance then you know the heater and defrost thermostat are OK so it must be a board problem.
File Attachment(s):
GB2FH.pdf (721kb) downloaded 25 time(s).
CurtDawg77
#3 Posted : Monday, July 21, 2014 5:01:51 PM(UTC)
CurtDawg77
Just wondering how to check these? I already ordered a control board to try out as I didn't see anywhere in the diagrams/part lists either of these two parts. Thanks in advance....
#4 Posted : Tuesday, July 22, 2014 1:09:44 AM(UTC)
The defrost heater is item 10 in section 06.
The defrost thermostat is not shown.
See the below.
The defrost thermostat should be 0 ohms when frozen.
The defrosts heater should be about 30 ohms,
Part number: AP4428815
bloodaxe23
#5 Posted : Monday, July 11, 2016 8:26:33 PM(UTC)
bloodaxe23
Denman I have been looking at this post and hope you can help me out. I have the same issues and stupidly ordered a circuit board after reading another post about a S in service mode meant a bad board. I see now I should have tested the heater circuit and thermostat circuit. I am trying to figure out if I can test these individually or is this best replaced as a group? thanks for the help..
#6 Posted : Tuesday, July 12, 2016 2:07:17 AM(UTC)
If the heater is bad then I would replace both.
If the heater is OK then I would just replace the defrost thermostat.
Also if the thermostat measures OK but is deformed/bulged, replace it.
bloodaxe23
#7 Posted : Wednesday, July 13, 2016 9:32:20 AM(UTC)
bloodaxe23
So I tested it last night and got 30ohms of resistance testing at pins 1 and 5 I saw thats good for the heater so thats probably ok? Should it also have resistance for the thermostat? And since Im getting the S on the panel when tested then most likely the thermostat is shoeted?
#8 Posted : Thursday, July 14, 2016 1:38:30 AM(UTC)
[COLOR="Blue"] I saw thats good for the heater so thats probably ok?[/COLOR]
Yes it looks OK
[COLOR="Blue"]Should it also have resistance for the thermostat?[/COLOR]
The thermostat should be 0 ohms when frozen and 56 Kohms (56,000) when thawed.
[COLOR="Blue"]And since Im getting the S on the panel when tested then most likely the thermostat is shoeted?[/COLOR]
Depends if it is frozen or thawed.
Guest (5)
MayTag defrost issues ????? (Refrigerator & Freezer Repair)
by HHM1435 10/16/2017 1:03:48 PM(UTC)
GE side by side defrost issue (Refrigerator & Freezer Repair)
by Craigesh 9/27/2015 8:00:03 AM(UTC)
Maytag MFB2055YEM Defrost Issue (Refrigerator & Freezer Repair)
by david@tidycottage.ca 4/28/2015 5:58:55 AM(UTC)
Defrost issue possibly?? HELP WRF989SDAM00 (Refrigerator & Freezer Repair)
by IslandWarrior 9/24/2014 6:34:33 AM(UTC)
GE Defrost Issues (Refrigerator & Freezer Repair)
by WVU 9/23/2014 7:40:11 AM(UTC)
by MelissaBarrera 7/24/2014 12:24:43 PM(UTC)
Diagnosing GE defrost issue (Refrigerator & Freezer Repair)
by tbarnett 7/8/2014 9:04:26 AM(UTC)
defrost issues (Refrigerator & Freezer Repair)
by jbain7005 10/16/2013 3:44:10 AM(UTC)
Freezer Defrost Issues (Refrigerator & Freezer Repair)
by smuth10 5/9/2013 5:10:31 AM(UTC)
Amana defrost issue (Refrigerator & Freezer Repair)
by CapeCoddah 4/8/2013 10:37:59 AM(UTC)
defrost issue? (Refrigerator & Freezer Repair)
by Frankie_Z 2/18/2013 7:44:04 PM(UTC)
GE PDS18SBMBLBS Defrost issue (Refrigerator & Freezer Repair)
by ldavisfl 12/8/2012 7:44:14 AM(UTC)
GE Profile Defrost Issue - Very Frustrated (Refrigerator & Freezer Repair)
by jaypp1 8/18/2012 7:20:53 AM(UTC)
GE Defrost Issue (Refrigerator & Freezer Repair)
by cmbicycles 8/15/2012 6:52:08 PM(UTC)
Defrost issues (Refrigerator & Freezer Repair)
by zeke7237 9/23/2011 3:29:06 AM(UTC)
