wernerb
#1 Posted : Monday, June 13, 2016 11:48:35 AM(UTC)
wernerb
Dishwasher isn't draining completely...have taken a part/cleaned everything. Doesn't go through disposal; has it's own drain from a air check valve on sink.
All hoses appear clear... Believe it is the solenoid...
Question: found somewhere reading should be 40 ohms with resistance/continuity test. It reads 33.8; is this off enough to indicate failure? Is 40 correct? Thanks.
Bill Werner
wernerb
#2 Posted : Wednesday, June 15, 2016 10:27:44 PM(UTC)
wernerb
Bump!
Bump!
