I have a maytag washer that does not spin or go through the cycle and drain properly so after reading all over the internet I replaced the shift actuator (twice) and it didn't make any difference. I also swapped out the capacitor just to be sure but nothing. I ran it through the diagnostic mode and it flashes the sensing light and the sensing, spin, rinse and done. After replacing the above mentioned parts I did a calibration test it ran for few seconds with water fill then sense and stops and the lid light flashes for a while and turns off.
Any idea what could be the problem, main board, lid switch?
Anyone that might know what could be the problem?
