Lott82
#1 Posted : Friday, May 20, 2016 6:33:24 PM(UTC)
Lott82
Frigidaire FRS26LH5D has just started this. When you activate the water dispenser in the door, water also flows in to the icemaker causing it to freeze up and also creating a solid clump of ice in the ice storage. Its like the valve that sends water to the door water dispenser is allowing water to get sent to the ice maker as well even though the ice maker is not calling for it. Thanks
Lott82
#2 Posted : Friday, May 20, 2016 7:25:35 PM(UTC)
Lott82
I read a reference to a diode kit? That might cause this, but I could not find a diode kit inbthe parts list.
