luck11
#1 Posted : Saturday, April 23, 2016 4:28:11 AM(UTC)
luck11
Hi. As per title, Fridge is decently cool (but set at max). I figure its about the temp if I set thermo inside the fridge to about 5 out of 10. Freezer is cool, but not freezing... popsicles melted (also set at max)
Last night
- cleaned all dust etc.
- compressor was very hot, not running
- fan next to compressor was running
- unplugged for about 1 - 1.5 hours and plugged in - can't remember if compressor ran, but don't think so.
This morning,
- found compressor is running, but it is still very very hot to touch
- removed PTC and checked...tiny rattle if I shake really hard, but get good test between side by side pins, so think it is okay
- found continuity on pins of compressor
- put it all back and plugged in, and compressor started immediately
That was about 10 mins ago.
Any thoughts of what might be the issue or what I might try next?
luck11
#2 Posted : Saturday, April 23, 2016 6:01:52 AM(UTC)
luck11
quick update:
So, I heard my compressor go off about 5 mins ago, and the fan next to it also turned off. Still have power in the fridge (lights work).
so now I am totally confused.
luck11
#3 Posted : Saturday, April 23, 2016 7:04:47 AM(UTC)
luck11
Update again.
Compressor and fan came on again after a while and have been on for a for a few hours.
I took the cover off the back of freezer to see frost pattern, and it there is only frost on the inlet tube and a bit on the coil. If I had to estimate, i would say the first 15% of the coil has frost. The rest nothing.
So, sealed system problem? Does this mean gas leak or could it still be bad compressor?
luck11
#4 Posted : Saturday, April 23, 2016 9:36:32 AM(UTC)
luck11
duplicate post
Appliance Medics
#5 Posted : Sunday, April 24, 2016 9:31:46 AM(UTC)
Appliance Medics
Unfortunately this means sealed system failure compressor is probably good just runs constantly to try to reach a temp it will never get to. Average cost of repair is about 800 bucks or so... might be time for a new one
