My water inlet valve is not working properly. I have removed both hot & cold hoses, cleaned the little basket filters then replaced. however i only get hot water. the cold water does not flow into washer:confused: Is there another test i can do before i take the washer apart?????
Most likely the problem with your washer is a bad water inlet valve which has to be replaced. - The part number for the water inlet valve is AP3094541 - Here are the break down diagrams for the Whirlpool washer Model LSQ8243HQ0Good luck. Gene.
