richard1520
#1 Posted : Monday, December 17, 2007 10:06:04 AM(UTC)
richard1520
My water inlet valve is not working properly. I have removed both hot & cold hoses, cleaned the little basket filters then replaced. however i only get hot water. the cold water does not flow into washer:confused: Is there another test i can do before i take the washer apart?????
#2 Posted : Monday, December 17, 2007 8:51:08 PM(UTC)
Most likely the problem with your washer is a bad water inlet valve which has to be replaced.
- The part number for the water inlet valve is AP3094541
- Here are the break down diagrams for the Whirlpool washer Model LSQ8243HQ0
Good luck.
