2 Pages12>
adamalbert
#1 Posted : 9 years ago
adamalbert
Hello,
We purchased Samsung rfg238aars refrigerator in Oct 2012.
The upper ice maker quit working. It is fusing one set of ice cube with the next. This won’t allow either set to move and drop into the ice tray. We tried the reset button without success. Please see Picture
We replaced the ice maker assembly. The new ice maker did exactly the same thing.
We replaced the water inlet value thinking it was letting to much water into the ice maker. This didn’t work
I am at a lost and open to suggestions.
Thank you,
Adam
adamalbert attached the following image(s):
Appliance Medics
#2 Posted : 9 years ago
Appliance Medics
Could be caused by low water pressure try replacing the filter and checking incoming water pressure.
adamalbert
#3 Posted : 9 years ago
adamalbert
Thank you Appliance Medics,
The filter was replaced in late March. The bottom ice maker and the water dispenser are working fine.
Never the less, I put a new filter in this morning. Worth a try.
Fingers crossed
Adam
adamalbert
#4 Posted : 9 years ago
adamalbert
I replaced the water filter yesterday. This morning the same issue: the first and second tray of ice fused together jamming the ejection mechanism.
Thank for the suggestion anyway.
Appliance Medics
#5 Posted : 9 years ago
Appliance Medics
Does the water come out of the door fine? Is it slow?
adamalbert
#6 Posted : 9 years ago
adamalbert
Appliance Medic
The water comes out of the door the same as it has for the last few years: no noticeable difference, and the bottom ice maker is working fine.
Appliance Medics
#7 Posted : 9 years ago
Appliance Medics
Last question would be is it leaking from the rear when it fills occasionally you can get a cracked water line that only causes your icemaker to half fill with water?
adamalbert
#8 Posted : 9 years ago
adamalbert
Appliance Medic,
I appreciate your taking an interest. I thought it a water flow issue, so I replaced the water value assembly. There is no leaking that I can detect. There is no water on the floor. The ice doesn't look sub sized, just forzen to the next batch.
Again thanks for thinking about the problem
Appliance Medics
#9 Posted : 9 years ago
Appliance Medics
Not a problem. This one sounds like I'd have to be there. Though you've replaced just about everything involved. Your not in maryland by chance? Lol
adamalbert
#10 Posted : 9 years ago
adamalbert
Thanks anyways, California would be a little far for a house call.
samsung ice maker for RS2545SH (Refrigerator & Freezer Repair)
by Guest 3 years ago
Samsung Ice Maker doesn't fill with water (Refrigerator & Freezer Repair)
by MJMarathon58 3 years ago
Samsung ice maker in GE Refrig - (Refrigerator & Freezer Repair)
by ken.musick72@gmail.com 4 years ago
Samsung Ice Maker RF266AERS/XAA (Refrigerator & Freezer Repair)
by korean1 5 years ago
Samsung Ice Maker (Refrigerator & Freezer Repair)
by krupp 7 years ago
Samsung ice maker frosting up (RF28HDEDBSR) (Refrigerator & Freezer Repair)
by Winchester30 8 years ago
Samsung ice maker fell into ice bucket, now jammed (Refrigerator & Freezer Repair)
by W_S 9 years ago
samsung ice maker DA97-02203G (Refrigerator & Freezer Repair)
by tlzfixer 9 years ago
Samsung Ice Maker Cubes Melting (Refrigerator & Freezer Repair)
by mbradenfl 10 years ago
Samsung ice maker problem (Refrigerator & Freezer Repair)
by retiredncolorado 10 years ago
Samsung Ice maker frozen water line (Refrigerator & Freezer Repair)
by MPM 11 years ago
Ice Tray for Samsung Ice Maker (Refrigerator & Freezer Repair)
by dlowry54 12 years ago
GE/Samsung ice maker overfills into ice bucket (Refrigerator & Freezer Repair)
by norgor42 12 years ago
Samsung Ice maker overfilling tray (Refrigerator & Freezer Repair)
by kb5oze 13 years ago
Samsung Ice Maker Line Freezing (Refrigerator & Freezer Repair)
by JoJoDaClown 13 years ago
2 Pages12>
