archieandveronica@msn,com
#1 Posted : Tuesday, April 19, 2016 12:23:50 PM(UTC)
My dryer shuts off in the middle of the drying cycle. It won't start again until it cools down. I have taken the back off and cleaned all lint away from vents and the motor. I have cleaned all vents and hoses all the way to the outside of the house. The unit is about 3 years old. Could it be a moisture sensor.
#2 Posted : Tuesday, April 19, 2016 12:31:08 PM(UTC)
I am new to this site and am having trouble navigating it as I don't understand a lot of what I am supposed to do
Appliance Medics
#3 Posted : Tuesday, April 19, 2016 12:35:30 PM(UTC)
Appliance Medics
That sounds awfully a lot like a bad motor. Can you tell if it is "straining" to run? Possibly sounds louder than it used to. Also make sure the drum can turn easily an there is nothing restricting it such as worn drum slides or a tight rear bearing.
