The Only Thing Working On My Control Panel Is The Auto Lite, All Button Will Blink The Auto Lite Twice Except For The Water And The Ice Button. I Put A New Main Control Board (back Of Ref) About Two Month Ago. I Order And Put In The Control Board (13053103sp) But Its Does Exact The Same As The Old Board. What Do I Need To Next
It could possible be either a control lock is on ( look for a symbol with a lock) that maybe you have to hold for 3 seconds to unlock or possibly a bad TouchPad itself.
I've held the lock for over 5 seconds only get a beep when push, the keypad seem to be responding when button are pushed except for the water and ice button which make no sound when pushed. All wires on control are put on corrected and TouchPad is seated. Ref & freezer is working maintaining the correct temp, ice maker working, just have to get ice out of container everything else on the control panel is blank out except for the auto light led. Any other ideas
I've held the locked button (number of times) for well over five seconds with not respond other than a beep when pushed, the touchpad seem to be working as I get a beep on all button when pushed except for the water and ice button. The ref and freezer is working maintaining the correct temperature, ice maker is working just have to get ice out of the ice container. I've try to get the code or pe to come up by pushing the upper left hand button and the lower right hand button and releasing the left
It seems to me a bad TouchPad W10740220. No lights when pressing the water or ice to indicate it's switching?
