Something strange happened over night. Yesterday my wife ran a load of clothes and the machine worked just fine. Fast forward to this morning and it wont fill with water at all. If I put it at one of the other stages in the cycle it will run but no matter what stage it will not fill.
This happens on hot or cold water. I have also tried different cycles, load sizes, hot, warm, and cold water. I will be checking the inlets momentarily but don't foresee any clogs. Almost sounds like a switch isn't being triggered.
Any ideas?
Figured it out!!
I took off the control panel and realized that the fill sensor was at fault, I unplugged the hose that feeds the pressure in and made sure it was cleared out and also unplugged the sensor from the power. Connected everything back up and voila it works like a charm again.
Originally Posted by: klturi421  Figured it out!!
I took off the control panel and realized that the fill sensor was at fault, I unplugged the hose that feeds the pressure in and made sure it was cleared out and also unplugged the sensor from the power. Connected everything back up and voila it works like a charm again. I'm having the same problem overnight just like you. Took off control panel checked hose. Hose is clear. How do I unplug the sensor from the power ? Where would I find that ? If u could help me I'd appreciate it. Just a single mom here trying to fix this.
