SkyNet3
#1 Posted : Thursday, February 25, 2016 12:46:10 PM(UTC)
SkyNet3
I have been trying to repair a GE dryer that at first wouldn't run. Power came on but timer counted down in seconds. I have replaced the Power board and now it runs but doesn't heat. I have tested the Hight Temperature Thermostat and have continuity. I do NOT have continuity on the Inlet Safety Thermistor. I have jumped the Inlet Saftey to bypass by still get no heat. Also is there any specific order the Red and Orange wires connect to the High-Temperature Thermostat as I faild to look before I removed them for testing. I also have continuity on the Heating coil and all other sensors. The only one that seems not to register is the Inlet Safety on.
.......HELP HELP HELP PLEASE:eek: .......
SkyNet3
#2 Posted : Friday, February 26, 2016 2:50:29 PM(UTC)
SkyNet3
Is this something no-one has had issues with before? Strange I get no replies...
