3 Pages<123>
#11 Posted : Monday, May 18, 2009 3:46:45 PM(UTC)
You are welcome. No, it does not.
Chan Patel
#12 Posted : Wednesday, May 20, 2009 4:06:07 PM(UTC)
Chan Patel
I just installed new defrost timer and turned on the ref. and it does not start.Is it a bad part?What is wrong now?
woodchuckie
#13 Posted : Wednesday, May 20, 2009 4:19:16 PM(UTC)
woodchuckie
The timer could be in the defrost cycle. Turn it till it clicks and see if everything starts then.
#14 Posted : Wednesday, May 20, 2009 4:33:56 PM(UTC)
Or just wait about 30 minutes.
Chan Patel
#15 Posted : Wednesday, May 20, 2009 7:52:25 PM(UTC)
Chan Patel
Gene and Woodchuckle,
Thanks a lot, I tuned it and it works .
#16 Posted : Wednesday, May 20, 2009 9:04:41 PM(UTC)
We are glad you were able to fix it.
Chan Patel
#17 Posted : Sunday, May 24, 2009 1:05:59 PM(UTC)
Chan Patel
The fresh food thermostat was turned from 5 to 7 to obtain 38 deg.F. temp.The freezer thermostat was turned from 5 to 6 yet the temp is 18 to 20 deg.F.I understand that the freezer temp should be 0 deg..F. to 5.deg. F.
Gene and Woodchuckle your input is required to resolve hopefully this last problem.Thanks in advance.
#18 Posted : Monday, May 25, 2009 3:06:45 PM(UTC)
Remove the evaporator cover and check how is the evaporator covered with snow. If there is not 100% of thin snow then most likely there is a problem with the sealed system. It can be low on Freon. It can be a restriction in the system. In such situation it has to be tested by a certified technician.
Chan Patel
#19 Posted : Tuesday, May 26, 2009 8:40:47 AM(UTC)
Chan Patel
Gene,
Thanks for your quick response.I will check out ASAP.
Chan Patel
#20 Posted : Friday, May 29, 2009 1:29:27 PM(UTC)
Chan Patel
Gene, you are right.There is no snow around the evaporator coil.The ice maker works the compressor is very hot and I can feel the heat by simply touching the top panel cover.What can be the reason for the compressor getting so hot?Thanks
Guest (4)
3 Pages<123>
