Blue2016
#1 Posted : Friday, February 12, 2016 7:20:44 AM(UTC)
Blue2016
Had some water boil over and it got around one of the knobs....Tried drying it out with a hair dryer and let it set for a couple weeks. When I tried to ignite it the knob just shorts out. Just unhooked everything. Is it worth having it fixed(if it can be) or would be just as costly to buy a new one. It's only about a 250-300$ too.Thanks
Joe / APP Team
#2 Posted : Friday, February 12, 2016 1:29:44 PM(UTC)
Joe / APP Team
Blue, The spillage probably caused a short in the switch and damaged the circuit. replacing the igniter switch assembly Part number: AP3783914
is relatively inexpensive and will probably take you 30 to 40 minutes to replace and test the cooktop for operation and ignition.
Blue2016
#3 Posted : Saturday, February 13, 2016 5:38:41 AM(UTC)
Blue2016
Thanks, appreciate the tip
Joe / APP Team
#4 Posted : Monday, February 15, 2016 5:19:14 AM(UTC)
Joe / APP Team
Blue, You're Very Welcome !!! Good Luck and Thanks,
Blue2016
#5 Posted : Sunday, February 21, 2016 6:33:18 AM(UTC)
Blue2016
Well the switch was toast, bought a new one and installed it, which was pretty simple. But as soon as I plugged it back up it just started clicking and the knobs were all off. Could something else have been damaged ?
Joe / APP Team
#6 Posted : Monday, February 22, 2016 5:52:57 AM(UTC)
Joe / APP Team
Blue2016, Recheck and make sure the switch or igniter wires weren't pinched or shorted between the panels or cooktop. If all's OK, then you have to presume the shorted switch, damaged the spark module Part number: AP3778816
, and it will need to be replaced.
Blue2016
#7 Posted : Friday, February 26, 2016 4:45:10 AM(UTC)
Blue2016
Well that fixed it. Everything works great!! Fast shipping on the parts.. Thanks again for your help!!
Joe / APP Team
#8 Posted : Friday, February 26, 2016 7:47:15 AM(UTC)
Joe / APP Team
Blue, Glad it all worked out. We're glad we could help you out.
You're Very Welcome !!! It was our pleasure. Thanks Again,
