4 yr old dishwasher most times after starting wash cycle run apprx 2-3 minutes then switches tto clean mode...each time it does this the soap dispenser has not opened..but, I don't know at what point it should open... have replaced the turbidity sensor and main electronic board to no avail....anyone have an idea to what the problem might be?
Originally Posted by: donb2  4 yr old dishwasher most times after starting wash cycle run apprx 2-3 minutes then switches tto clean mode...each time it does this the soap dispenser has not opened..but, I don't know at what point it should open... have replaced the turbidity sensor and main electronic board to no avail....anyone have an idea to what the problem might be? Have similar issue changed control board will be trying to replace power module next.
