LMA
#1 Posted : Saturday, January 30, 2016 8:40:53 AM(UTC)
LMA
Groups ready for retrieval: Registered
Just started. Top loader. It's about 10 years old. Sounds like ball bearings when we turn it on. Drum doesn't move.
Trying to find out if this may be worth fixing myself, our just sittingl spring for a new one altogether.
Thanks for your help
P.s., Where would I find the model on these?
sidfink43
#2 Posted : Saturday, January 30, 2016 9:35:50 AM(UTC)
sidfink43
The model number is under the lid on the back of the frame of the opening.
Can you give us more details along with the model number, for example, does it fill and then have the noise, does it agitate etc.
LMA
#3 Posted : Saturday, January 30, 2016 10:07:32 AM(UTC)
LMA
Thanks.
Looks like the model number is: kaws750lq2.
It fills/drains. Doesn't spin or agitate.
sidfink43
#4 Posted : Saturday, January 30, 2016 10:26:56 AM(UTC)
sidfink43
You have the classic symptoms of a broken motor coupling. That's good news, an easy and inexpensive repair. Here is the part
Part number: AP3963893
and note the video that shows you how to fix it. It will help greatly to have a helper.
LMA
#5 Posted : Saturday, January 30, 2016 12:17:32 PM(UTC)
LMA
Thanks. Another unrelated question. Same washer. This has been going on for a could years. Washer won't always start when the lid is closed. Usually you need to slam the lid pull a"fonzie" (for those of you old enough to know what that means:
sidfink43
#6 Posted : Saturday, January 30, 2016 12:34:21 PM(UTC)
sidfink43
Okay, classic symptoms of a bad lid switch. Again, an easy and inexpensive repair, one you can do when you take the cabinet off to fix the coupling.
LMA
#7 Posted : Saturday, January 30, 2016 12:41:27 PM(UTC)
LMA
Thanks.
Is there a specific video I should watch for that, or are they pretty much all the same once the cover is off?
And a link to the part please
Thanks again
sidfink43
#8 Posted : Saturday, January 30, 2016 1:02:00 PM(UTC)
sidfink43
Here is your part and video. Really it doesn't get any easier than this.
Part number: AP3180933
