jmcd6344
#1 Posted : Monday, January 18, 2016 1:13:22 PM(UTC)
jmcd6344
The lower spray arm will not rotate, even when trying to turn it by hand. The spray arm holes are clean and water comes out freely.
joe
#2 Posted : Tuesday, January 19, 2016 12:43:02 AM(UTC)
Parts for DWU7400 - AppliancePartsPros.com
You will have to choose the correct unit from the Matching model Numbers section.
As far as I know the spray arm should turn easily by hand so you will have to take it apart to figure out what is going on.
Below is a link to a manual which should help you.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...wnloads;sa=view;down=420
jmcd6344
#3 Posted : Saturday, January 23, 2016 9:20:47 AM(UTC)
jmcd6344
thanks denman. Disassembled everything this am, as we are snowed in here in Philly. The pump filter was caked with calcium and had bent in which impacted the spray arm movement. Just ordered a replacement from APP. When I lifted the strainer out, there were two plastic rings. Any special way they need to go back in?
#4 Posted : Saturday, January 23, 2016 11:08:55 AM(UTC)
Take a look at the Latest Questions
Part number: AP4111379
Guest (4)
