The lower spray arm will not rotate, even when trying to turn it by hand. The spray arm holes are clean and water comes out freely.
joe
THIS FORUM IS DEAD!!!!!!! |
thanks denman. Disassembled everything this am, as we are snowed in here in Philly. The pump filter was caked with calcium and had bent in which impacted the spray arm movement. Just ordered a replacement from APP. When I lifted the strainer out, there were two plastic rings. Any special way they need to go back in?
