afzallodi
#1 Posted : Tuesday, May 19, 2009 6:02:45 PM(UTC)
afzallodi
Compreessor Never Turns Off
afzallodi
#2 Posted : Tuesday, May 19, 2009 6:07:51 PM(UTC)
afzallodi
PL ANSWER MY QUES
afzallodi
#3 Posted : Tuesday, May 19, 2009 6:12:25 PM(UTC)
afzallodi
PL ANSWER MY QUES
PL ANSWER MY QUES
johnstaleyCLT
#4 Posted : Tuesday, May 19, 2009 6:37:32 PM(UTC)
johnstaleyCLT
Is it getting cold in fresh food area and freezer?
woodchuckie
#5 Posted : Tuesday, May 19, 2009 6:48:02 PM(UTC)
woodchuckie
Will it cut off when you turn the freezer control warmer? If Yes. Is it getting to the set temp or is it too warm?
If it doesn't cut off before it gets to the off position then the cold control is bad if the freezer is cold enough. If the freezer isn't cold enough you probably have a defrost problem or both fans are not running.
afzallodi
#6 Posted : Wednesday, May 20, 2009 10:14:42 AM(UTC)
afzallodi
it side by side frigidaire refrigerator , both sides get cool according to their set point, but compressor never turns off.
afzallodi
#7 Posted : Wednesday, May 20, 2009 10:23:34 AM(UTC)
afzallodi
yes freezer and vege area gets cold, but compressor keeps on running
johnstaleyCLT
#8 Posted : Wednesday, May 20, 2009 11:33:30 AM(UTC)
johnstaleyCLT
I assume you have checked for dust on the coils under or behind refrigerator and overheating is not an issue.Check the freezer coil by removing the cover ( usually the back inside wall near the bottom).
It should be evenly frosted from top to bottom. If ice is forming only near the tpo , you are probably low on freon. Hope this helps, John
Guest (4)
