Compreessor Never Turns Off
Originally Posted by: afzallodi ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Compreessor Never Turns Off PL ANSWER MY QUES
Originally Posted by: afzallodi ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) PL ANSWER MY QUES PL ANSWER MY QUES
Is it getting cold in fresh food area and freezer?
Will it cut off when you turn the freezer control warmer? If Yes. Is it getting to the set temp or is it too warm? If it doesn't cut off before it gets to the off position then the cold control is bad if the freezer is cold enough. If the freezer isn't cold enough you probably have a defrost problem or both fans are not running.
it side by side frigidaire refrigerator , both sides get cool according to their set point, but compressor never turns off.
yes freezer and vege area gets cold, but compressor keeps on running
I assume you have checked for dust on the coils under or behind refrigerator and overheating is not an issue.Check the freezer coil by removing the cover ( usually the back inside wall near the bottom). It should be evenly frosted from top to bottom. If ice is forming only near the tpo , you are probably low on freon. Hope this helps, John
