markandpam
#1 Posted : Saturday, January 16, 2016 3:46:35 AM(UTC)
markandpam
my oven element went bad. actually I was surprised as the home is a part time winter dwelling that we rarely cook in. I purchased an element and installed it yesterday. Now the breaker wont set?
#2 Posted : Saturday, January 16, 2016 7:39:52 AM(UTC)
Remove power from the unit.
Then remove the element and check that it is exactly the same as the old element.
What is critical is the distance from the plate that holds the element to the back of the oven cavity to the end of the element connections.
If too long it can short out to the rear cover plate in the oven.
Check the replacement element with a meter.
Check it's resistance. I do not know what it should be but is probably 20+ ohms.
Also check from each element connector to the mounting plate and any feet that it may have. All should be infinite ohms.
If all OK you may want to tape up or somehow make sure that the connectors cannot short to each other or anything else and then try to reset the breaker.
If it still will not reset then you know that the element is not the culprit and you will have to dig deeper.
markandpam
#3 Posted : Saturday, January 16, 2016 10:36:56 AM(UTC)
markandpam
thanks for your reply......found the breaker to be bad
#4 Posted : Sunday, January 17, 2016 1:22:27 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Guest (4)
