Replacement parts for FRIGIDAIRE GLEQ2152ES0 Frigidaire/dryer | AppliancePartsPros.comHere is a tech sheet. The wiring diagram is more legible than the one with the parts.
http://manuals.frigidaire.com/p...ebster/134509400efsa.pdfAnd here is a service manual.
Frigidaire 27 inch Dryers Gas and Electric Electronic Controls (5995393146) Service Manual - ApplianceDigest.comThe "ad" looks like it stands for auto-dry. See page 15 in the manual.
I would check the power first to be sure you have 240 volts going to the dryer.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
Next check the heating element.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around13 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
Next check the high-limit thermostat, should be 0 ohms.
Next check the thermistor, should be around 50,000 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
