shawn40
#1 Posted : Thursday, January 5, 2012 2:53:38 AM(UTC)
shawn40
dryer turns but no heat, error code ad that nobody seems to be able to find, cleaned out the lint all the way to outside, reset the breaker, still no heat and the code comes up after about 5 minutes, i think it might be the element, any ideas??? and were might the element be located and what is the easiest way to get to it?
#2 Posted : Friday, January 6, 2012 1:38:09 AM(UTC)
Replacement parts for FRIGIDAIRE GLEQ2152ES0 Frigidaire/dryer | AppliancePartsPros.com
Here is a tech sheet. The wiring diagram is more legible than the one with the parts.
http://manuals.frigidaire.com/p...ebster/134509400efsa.pdf
And here is a service manual.
Frigidaire 27 inch Dryers Gas and Electric Electronic Controls (5995393146) Service Manual - ApplianceDigest.com
The "ad" looks like it stands for auto-dry. See page 15 in the manual.
I would check the power first to be sure you have 240 volts going to the dryer.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next check the heating element.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around13 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case.
Next check the high-limit thermostat, should be 0 ohms.
Next check the thermistor, should be around 50,000 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
shawn40
#3 Posted : Friday, January 6, 2012 2:37:44 AM(UTC)
shawn40
denman, thanks so much for the info, my wife got worried as laundry was piling up and in the mean time i pulled an old dryer out of the basement and switched it out, i know i am capable to fix this thing, i built this house 4500 sq. ft. by myself and repair most any of our heavy trucks and equipment in our tree company anyway the service man that came out said we should think about buying a new one but its only 6 years old. he said it needed a heating can assembly, top and lower felt,rear bearing kit and a control board, this seems crazy that this would all go out at the same time, what are your thoughts as now i have plenty of time to fix it since we have a working dryer for the time being or should i just junk it? Thanks for your help!!!
#4 Posted : Friday, January 6, 2012 4:35:14 AM(UTC)
[COLOR="DarkRed"]he said it needed a heating can assembly, top and lower felt,rear bearing kit and a control board, this seems crazy that this would all go out at the same time[/COLOR]
Unless he opened it up and tested things he is just guessing.
The felts are a mechanical thing so you just have to look at them to see their condition.
Same with the rear bearing. Usually they squeal when they are gone but it could be that it is worn allowing it to move around and that screwed up the front felts. If it is OK clean out the old grease and re-lube it using a high temperature grease.
Seems strange that both the control board and heater are shot. There is a possibility that the heating element shorted to the case, drew too much current and welded the heater relay contacts together. Again I am second guessing the service rep and it depends on what tests he did.
[COLOR="DarkRed"]what are your thoughts as now i have plenty of time to fix it since we have a working dryer for the time being or should i just junk it?[/COLOR]
Open it up and take a look.
Without being there I cannot give any really reliable advice on this.
I do agree that if you have to open it up you may as well give it a basic overhaul.
sbkotcd
#5 Posted : Monday, February 25, 2013 5:23:31 PM(UTC)
sbkotcd
I have a similar problem. I had a serviceman come look at my dryer, he replaced the thermistor, and now we have heat again. However, now the heat will not come back on while in a cycle. The code goes to AD, and eventually shuts off = wet clothes. Any idea why the heat will only go on in the beggining of the cycle?
kado1976
#6 Posted : Wednesday, January 13, 2016 12:12:53 PM(UTC)
kado1976
Originally Posted by: denman Go to Quoted Post
If OK
If OK
So I checked my high-limit thermostat at .1 or so. Its still good right?
I cant find the issue with my dryer!
darien685
#7 Posted : Wednesday, August 24, 2016 7:50:33 AM(UTC)
darien685
I have a Frigidaire Gallery Series dryer. I got it about 10 years ago. Work great. Now about 2 days ago it has no heat. What should I check first. Any help would be great. Thanks:)
Guest (4)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
