sarahandbray
#1 Posted : Tuesday, January 12, 2016 12:16:19 PM(UTC)
sarahandbray
This is a great forum!! Looking for assistance. While baking cookies last night in both ovens, the first batch went fine. On second batch, I could not get them to finish baking/brown. Thought it was the dough. Turned on oven today to make dinner and neither oven heats up. Keypad is fine, all digital numbers light up, fan goes fine in back of oven. No heat beyond BARELY warm. Can easily touch inside of oven with bare hands. No circuit breaker issues in basement.
Any ideas? Both worked fine and then stopped heating at the same time.
Guesses from quick online research are Thermal Fuse, Dual Oven Relay Board or Oven Control Board. Purchased ovens in 2006.
Please advise!
Call in to service company but hate to have them come out. Was able to fix my Bosch dishwasher from online research and hoping this will be an easy fix, too!
Sarah
#2 Posted : Wednesday, January 13, 2016 1:59:17 AM(UTC)
Parts for Frigidaire PLEB30T9FCA Oven - AppliancePartsPros.com
See the attachments for the data sheet and the wiring diagram.
First you have to check the power to the unit.
Just because breakers look OK does not mean they are OK.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the power where the house power connects to the units wiring.
Do this with a oven off and on.
If you do not have experience with electrical I would get a pro in other than flipping the breakers.
