AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Just need ground wire and screw, but can't seem to order just that HELP
All I need is a neutral ground wire and the screw that attaches it to the back of the machine but it doesn't appear that I can order just that. Am I going to have to buy the whole Terminal Block Kit just to get a new neutral ground wire? I bought the machine used and the green neutral ground wire is missing. Whirlpool 279320 Terminal Block Kit - AppliancePartsPros.comThanks
I am not sure what the problem is. Any piece of 14 gauge wire will do. Stranded wire is better if you have it, as it is more flexible.
As long as you have another connector or a washer between it and the screw head so the wire does not twist when you tighten the screw.
If you are missing the bolt in the terminal block then finding the correct one may be a bit of a pain. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
